Hide a part of bouncing particles (Water spalsh)
by Simon Luchini Duca on Dec 12, 2012 at 3:02:07 pm
Hallo everybody,
I'd like to know if is possible to hide a part of a bouncing particles. I'm creating a water spalsh but I wouldn't see the origin's emitter and also the falling particle but just the bouncing particles (over an invisible ground as a SOLID with Opacity 0%), but only the expanding splash, to be clear.
Is it possible or I've to mask ...?
Re: Hide a part of bouncing particles (Water spalsh) by Vishesh Arora on Dec 13, 2012 at 9:57:33 am
Simon
It is possible.
1. Use Aux System for creating the Bouncing particles.
2. Bring the Size of Main Particles to Zero. Now you will be having just the Aux particles.
3. Choose Bounce in Physics instead of Air and and a Solid as Floor Layer and bring its opacity to zero.
Re: Hide a part of bouncing particles (Water spalsh) by Simon Luchini Duca on Dec 13, 2012 at 11:46:54 am
Great V,
but now the bouncing particles are to much regular... not as a water spalsh. How can I randomize the particle direction and bouncing elevation? Any ideas?
