|  | Re: how can i create a net? (like the basketball hoop ) by Eric Santiago on Nov 1, 2012 at 6:00:28 pm |
animated with ncloth dynamics?
then you need to create an actual mesh system.
Id model it the way you see it.
if its just for prop and not a cu, then use a open cylinder and transparent mapped grid angled 45degree in map.
