 | need a web designer with php YII Framework programmer to continue development of a working webportal
by Lili Gates on Oct 30, 2012 at 6:55:16 am |
The original programmer who wrote the system is not available - we need someone who can fix bugs in the system and build a few new modules and to continue working with us long term supporting and upgrading the system - we would like to spend a few hundred dollars per month on upgrading and fixing the system as we are launching. We are a small company - the web site is not generating a lot of profits yet. We need someone who will understand what we are trying to do and can do this on their own without our interference. We are expecting about 4-5 different web sites / modules to be operating together within the same portal all interchangeable - the main modules / sites are already designed and built. You should have a lot of free time - and love for programming and good knowledge of PHP knowledge of the YII Framework is a big plus.
The first system we need is a calendar system and a calendar search system.
we are looking for someone excellent - but more of a student level rate - we can not afford to pay high rates - and can extand our budget slightly but really need to spend only a couple of thousand dollars over the next year or so.
Are you able to work for very cheap and get a lot of work accomplished? We would be glad to increase the pay rate as our system begins to generate more revenues - but for now - we can afford very little - and we really need a lot of work. We need someone who loves this type of work - and has the free time to do it. This is a job and work offer for a freelancer web developer / web designer.
