FORUMS: listlist (w/ descriptions)archivetagssearchhall of famerecent posts
PolyChome Not Showing After Install (SnowLeopard)
Cow Forums : CoreMelt Plugins New !
by jeffrey fitzgerald on Oct 27, 2009 at 7:05:55 pm
I have a clean install of SnowLep and have ran the CoreMelt installs for FCP7. The C2 installed and works fine. But my PolyChrome transitions are not there. Any ideas?
Re: PolyChome Not Showing After Install (SnowLeopard)
by Roger Bolton on Oct 28, 2009 at 12:18:21 am
Hi, do you mean that the older version (requires FxFactory) version of PolyChrome transitions is not showing up? In CoreMelt V2, PolyChrome appears as "C2 TRX: Filmic Transitions" and "C2 Delta V: Motion Transitions", the pack was split up and renamed.
If you need the older version of PolyChrome for compatibility with older projects you can install it from here:
http://www.coremelt.com/support/overview/coremelt-versions-for-fxfactory-us...
Roger
CoreMelt
FORUMSTUTORIALSMAGAZINETRAININGVIDEOS - REELSPODCASTSEVENTSSERVICESNEWSLETTERNEWSBLOGS
