I'm taking a Sony PDW-F800 XDCAM to an oil rig soon. It's for UK (PAL) broadcast and we should be shooting 1080, 50mbps, 4:2:2 HD, interlaced.
The rig operates on a 60Hz electricity supply so I presume I set ECS to on at 60Hz, to compensate for any flickering with internal lights.
I'm taking some LED light panels that will probably be run on batteries.
So if I'm shooting interior with house lights and my battery run LED's will this cause me a problem?
If it's an exterior would it matter if I left ECS on at 60Hz?
If I end up having to shoot progressive at 25p I'd have the shutter set at 1/50 (180degrees), so can you then set the ECS on as well or does that override the shutter?
Thanks in advance for any help.
http://www.simoncoxcameraman.co.uk
