| Creating a SAN for the first time
by Ritesh J g on Oct 22, 2012 at 10:29:11 am |
Hi Guys, i am completely new to this, and i need help setting up a SAN.
I am supposed to be using Raid, question is which RAID?
Firstly i have a HP storage server which holds 12 drive bays that have each 146GB hard drive each.
Out of the 12 i would like -
2 disks - holds operating system (was planning to use openfiler)
10 disks - holds the storage which is resilient
the main question is how do i get this setup and how do i know what raid to choose?
this is all the information i have, thank you in advance.
RG
Hi Ritesh,
Sounds like what you are setting up is not a SAN, but a NAS. With a NAS you can share the storage via standard network protocols such as SMB/CIFS.
Using RAID 5 means you can lose one physical drive without losing data.
Using RAID 6 means you can lose two physical drive without losing data.
RAID 5 typically offers better performance than RAID 6.
In the end, it depends on how critical your setup is and if you have a backup procedure in place.
With regards to operating system, your only option should be RAID 1 for mirror.
Good luck,
Bernard
• | | | |  | Re: Creating a SAN for the first time by Ritesh J g on Oct 22, 2012 at 1:16:25 pm |
Thank you Bernerd for your reply so soon, i will give it a try using Raid 5 and Raid 1 for the operating system.
If i am stuck anymore than i will mail back, but at the moment i may try spend sometime getting the configuration setup.
• | | | |  | Re: Creating a SAN for the first time by Bob Zelin on Oct 22, 2012 at 7:40:04 pm |
146 gig drives are tiny for this application. How old is your system ? Are these even SATA drives ?
Bob Zelin
• | | | |  | Re: Creating a SAN for the first time by Ritesh J g on Oct 25, 2012 at 11:14:45 am |
Hi Bob i was looking for help not to be critisized for what storage i have. And yes the system is an old one which i had since 2007 but i am trying to make use of it
