3DS MAX:3ds Max Forum3ds Max Tutorials3ds Max
simple inset question
COW Forums : Autodesk 3ds Max
Share on Facebook
Eugene Hoopersimple inset question
by on Sep 20, 2012 at 12:22:39 pm
Hey guys, new to 3ds max here. I've got what should be a simply task but the inset function under polygon modeling isn't behaving the way I'd like it to. I've got these 4 polygons I'd like to inset:
http://imgur.com/wprcM
but when I do, it looks skewed and not inset proportionally:
http://imgur.com/5WK69
The height and width of those 4 polygons are the same so I'm not sure why it's insetting it more vertically. I'm sure this is glaringly obvious to you guys but I'm clueless as to why it's doing that.
Thanks in advance! Much appreciated.
cheers,
Eugene
Reply   Like
Joseph W. BourkeRe: simple inset question
by on Sep 20, 2012 at 3:05:01 pm
Hi Eugene -
When you look at the Caddy - the mini interface which you show in your screen shot, the first box below "Inset" should give you your answer. When you click and hold you should get two choices, Group, or By Polygon. I think one of those will solve your problem.
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com
Reply   Like
Eugene HooperRe: simple inset question
by on Sep 21, 2012 at 1:55:44 am
Hey, I've tried them both. It's definitely meant to be by group, which I have it set to. The other one is by polygon and that's not the result I'm after.
any other alternatives?
thanks
Eugene
Macbook 2.4Ghz Intel Core 2 Duo, 4GB RAM
Reply   Like
by on Sep 21, 2012 at 11:59:42 am
Sorry that didn't help. The only other thing I can see from your sample is that it looks as if the outline is being somehow constrained to an axis - is it possible that you have any constraints turned on that would limit the funtions of outline?
Joe Bourke
Bourke Media
Reply   Like
by on Sep 23, 2012 at 6:27:06 am
nope no constraints as far as I can tell. I could have accidentally hit something though without knowing it. could it be the axis orientation or something like that? this is quite a pain as the inset function is integral to modeling in max and preventing me from going any further...
Eugene
Reply   Like
by on Sep 23, 2012 at 5:18:29 pm
Do you by any chance have Edit Constraints turned on in Edit Poly? That could be the culprit. It's in the Edit Geometry section.
Joe Bourke
Bourke Media
Reply   Like
by on Sep 24, 2012 at 10:03:47 am
hey, under the Edit Geometry section I see a 'Constraints' section with 4 options
-None
-Edge
-Face
-Normal
Is this what you meant? Currently its set to None, but I've cycled through the other options and given it a go but get the same results when using the inset function.
Eugene
Reply   Like
by on Sep 24, 2012 at 1:29:12 pm
That's what I was referring to. Sorry it wasn't the solution. There are so many possibilities here - I think the simplest solution here is to just use the grid, select your vertices, and move them around until they look right. Now that I look at the model, it looks as if the angle the edges are coming in to it on the top is affecting the way inset is working. If you notice, the edges on the bottom are coming in and attaching at an angle (excluding the middle one). On the top half of the model they're not. I think that may be the problem.
Joe Bourke
Bourke Media
Reply   Like
by on Sep 27, 2012 at 9:31:41 pm
cool thanks, I'll investigate.
cheers!
Reply   Like
David ChappellRe: simple inset question
by on Oct 3, 2012 at 12:01:39 pm
It may be worth resetting your x-forms - depending on how you modeled the structure it could have all gone abit wonky ;)
Under your hammer (utilities) select Reset XForm and then collpase your stack - then try again.
It often fixes unexplained oddities.
David Chappell
Freelance Motion Graphics / 3D
http://www.IncidentalTrees.co.uk
Reply   Like
by on Oct 4, 2012 at 9:33:17 am
holy f***ing s***.
you sir, are a genius. inset function is now working perfectly. I cant thank you enough. I can now resume my 3ds quest I had so easily given up on.
cheers man,
Eugene
Reply   Like
by on Oct 4, 2012 at 10:10:14 am
Good stuff!
David Chappell
Reply   Like
Share on Facebook
