Hi,
well, I exported a photo show and the program gives me the following options while exporting:
Video preset - Type: HD, Quality: 1080p
Format: MPEG 2 (no other choice possible)
Compression: MPEG VIDEO (no other choice possible)
Resolution: 1920x1080 (no other choice possible)
Framerate: 59.94 (no other choice possible)
Aspect Ratio: 16:9 / 4:3 / Square Pixels
Encoding: Normal quality / High quality
Desaturation: checked, Desaturate images to 80%
Anti-Flicker: checked, Apply anti flicker filter to video.
That's all I can adjust before creating a HD video file. And this mpg file is about 16gigs in size, but in Encore its size decreases.
@Jeff: Thanks for your post, but as you can see, I don't work with Premiere in that case. I'm struggling with the photo show software that just lets me export HD mpg files with the above mentioned settings.
